is it possible to import many SpSimplePortfolio items to joomla?
Important for me:
Title, image, description, tags, category, language
Thanks for answers
Important for me:
Thanks for answers
Sorry, there is no way to import or export the portfolio items or properties.
Thanks for contacting us.
If you are using SP page builder integration for SP Simple Portfolio, then you can import/export, but this will let you have that part you used SPPB to build I mean description only. Not the parts you built with sp simple portfolio.
Here is screenshots:
Thats all you can do with this.
Thanks for your answers.
I've found the solution:
IMPORTANT
I have noticed that image files must have file extension write with lowercase.
Thank you so much for sharing your experience with us!
I ran into another problem:
I've imported many items. They are all ok, but when I execute thumbnails generating i receive:
"Fatal error: Maximum execution time of 30 seconds exceeded"
Is it possible to run the reset function resetThumbs() to bypass the "Maximum execution time" limit?
- Create or edit .htaccess file.
- Put into the file:
php_value max_execution_time xxwhere xx stands for the new value of a parameter.
source: https://forum.joomla.org/viewtopic.php?t=216202
