HI
Can I make a SPPB module fluid so it fills the whole width of the page?
Alison
HI
Alison
Please use the following code in your custom CSS to make it full width:
#sp-bottom .container {
max-width: 100%;
padding: 0 !important;
Note: Path towards custom CSS: Extensions>Templates>Styles> Click on your current default template name then choose Template Options. Then find custom CSS within the custom code.
Thanks for contacting us.
If you do not enabled the box layout, then with the help of modifying margin, padding vallue it can be achieved I think. Which module you are talking about, please? Can you redirect me to where you have that module to check?
Module 440
shows in module position [top-footer] on all pages
Thank that works.
Is there a way to remove the white space above and below the module?
Glad to know that the code is working:)
There is module title shows in white color. Please have a look: https://prnt.sc/24jrwqq
So you can choose to remove the module title from module edit window.
And please remove margin, padding values from your module and section.
You can use the following custom code either:
#sp-bottom .sp-module, #sp-bottom {
margin: 0;
padding: 0;
#sp-bottom .sp-module .sp-module-title {
display: none;
OK, thanks, I put in a margin top and bottom of -70 and that worked (I think)
Glad that it worked for you and you are always welcome:)
