Remove logo text
Asked by Marcos Oya 3 years ago Last activity 3 years ago
Rashida Rahman Staff
Sorry for your issue.
Have you uploaded a white logo in your logo area of the Template Options, please? https://prnt.sc/nWyTic9ZY1Is
And it seems you have not enabled the sticky header option too. https://prnt.sc/ng_JfeCMg_-8
The white logo concept is, it will appear when you scroll down to the page the header background will be darker and the white version of your logo image will appear in fixed header.
2 more replies
Marcos Oya Asked this
Hello again,
My problem is that I have created a custom menu and below the logo, the name of the website appears in text.
To solve it, it is necessary that the line that I have created in the layout builder to add the logo and the menu is called "header"
t's solved.
Thank you.
Glad that it is solved and thanks for sharing your experience with us.
