OpenGraph Settings - Forum | JoomShaper
OpenGraph Settings
Asked by Klaus Liedtke 3 years ago Last activity 3 years ago
in PB i choose a page.
Then settings ---> SEO
Put the informations in fields:
OpenGraph Title, OpenGrapg Images and OpenGraph Description
Then save.
Message "Page-Settings successfully save"
Then Save Page.
Exit
Clear Cache.
Once again
Open PB, CHoose the same page.
Open Settings SEO
All informationen about OpenGraph are gone.
Whats the problem?
Hi Klaus,
  1. What version of SPPB you have?
  2. Can you share access to admin area as Super User?
Klaus Liedtke Asked this
Hi Paul,
Pro Version 4.0.7
You have installed TAGZ - I had this same problem in the past, so we (me or you) have disable SPPB from that extension. This is source of problem, not SPPB!
but I will check deeper
Hi Paul,
I installed TAGZ just a minutes ago, cause PB Open Graph is not working.
Ok, good to know.
Fixed, SPPB settings only.
Hi Paul,
It's okay.
I'm happy with TAGZ and will not need th PB version.
Thx
Fixed. By mistake(?) you disabled OpenGraph in SPPB Options
Now is 100% ok, evidence of OG working code - (below)
About TAGZ - you can keep for articles, etc.
Hi Paul,
TAGZ is not aktiv.
in PB Open Graph is enabled.
Try'd to save OpenGraph Infos on Page "Folienrechner"
Is still not working.
For FAQ page was OK,
I will check that page.
