i have a problem with sp image gallery. I made a gallery but the template isn't the same of my homepage.
homepage:
https://www.johnlordgioielli.com/it/
homepage:
Did you use a menu item to show your sp easy image gallery?
Then you have option to choose the template within menu edit window.
You can check that option if it set differently.
hi, i think i don't use a menu item to show the gallery. the poblem is that i have 2 different color of the mneu bar and a white row is inside the menu bar
hi the problem is in the gallery page the menu bar is black with a white row and scrolling the menu is blue
best regards
