Template Fusio: After Update I cannot change the Layout
Asked by Michael 3 years ago Last activity 3 years ago
Dear Support Team
I just want to change some layout on the Template.
When I hit save, I got the message : Error:undefined
All changes are not saved then.
Im not srue, but maybe its after one of the last the Updates from PageBuilder but not know wich one, because I did not try to change the layout for a longer time.
Thank you for your help.
Regards
Michael
Michael Asked this
Template Fusion
I appreciate you reaching out. I sincerely apologize for this oversight. Please check the screenshot & contact your hosting provider.
https://prnt.sc/c2d5GaRR6WXP
-Thanks
Michael Asked this
Hi Toufiq
The question is, why do you try to make an SQL-injection?
Thas not a Problem,thats the Firewall that blocks this. That has nothing to do with the Problem of the Template, right?
Or did this shows when you try to analyze something? If yes, I can temporary disable the firewall.
Regards
Michael
Did this shows when you try to analyze something? If yes, I can temporary disable the firewall.
Yes, when i try to analyze something it displayed.
Michael Asked this
Really strange, after I deactivate the Firewall and reactivate it, it works again. Did you already done something?
Your firewall was occurred the problem to load the resources of page builder. Thanks
