Indigo Template Not Working - Question | JoomShaper
D
debanks
Template 5 years ago
Hello I can not seem to install the indigo template onto my website. I have been using joomla for years and have never had a problem. I am getting the error message cant find Joomla XML set up file. I hired a professional joomla webdesigner and they tell me there is a fault with the template. Please help
Senior Staff 5 years ago #13015
Hi, I have doubts if he is for sure "professional" otherwise he would use alternative method of template installation. Or maybe he just forgot about those steps.
  1. Check if you can install any other template, for example, use Helix Ultimate template package.
  2. Then download Quickstart package and upload folder /template/shaper_indigo from it
  3. In Joomla Admin: Extensions - Discover - Click Discover button - Install found template
  4. Check if Helix Ultimate plugin is enabled from step (1)
  5. Later check System - System Information - Folder Permissions
D
debanks
5 years ago #13023
Ok helix template wont upload either, error message below
JInstaller: :Install: Can't find Joomla XML setup file. The Joomla package cannot be installed through the Extension Manager. Please use the Joomla! Update component to update Joomla.
Senior Staff 5 years ago #13026
So now you're 100% sure that - it's not our issue ! Many topics with answers are here: forum.joomla.org
In Joomla admin: check System - System Information - Folder Permissions . My role ends here.
D
debanks
5 years ago #13120
Not sure how to do this, I am not sure why it is so difficult to install, I have never had this problem before. Perhaps I should just get a refund and find a template elsewhere?
Senior Staff 5 years ago #13302
Maybe download and try to install free template from different developer - probably you would get this same issue.
BTW Are you able to install any/random extension?
We are not Joomla support. I told you to search on offcial joomla forum, there are tons of similar topics with answers.
Senior Staff 5 years ago #13303
Every template can be installed manually as well. Using FTP tool. It takes only 3minutes more. If hired by you developer cannot do that, I can.
