How To Disable The Bookmark Icon In Article Layout Widget - Question | JoomShaper
JR
Javier Rojo
Template 5 years ago
Hello:
How can I disable the bookmark icon in the article layout widget in Newsberg template? thank you.
Ariba
Ariba
Support Agent 5 years ago #15826
Hi, You can use this custom css
.article-spbookmark { display: none !important; }
 span.bookmark-text { display: none !important; }
Add this css code inside the custom.css file.
Note: Path towards custom CSS: Extensions>Templates>Styles> Click on your current default template name then choose Template Options. Then find custom CSS within the custom code. https://prnt.sc/pu705g https://prnt.sc/pu70zn In Extensions>Template> Template Options > Custom Code > Custom CSS please add this Thanks
JR
Javier Rojo
5 years ago #15828
Thank you, it worked fine :)
Ariba
Ariba
Support Agent 5 years ago #15929
You are most welcome.
Have a nice day.
