SP Easy Image Gallery - Question | JoomShaper
T
TKIF2016IT
Extension 1 year ago
hi when i try to drop en image i have this error
VM3813:1 Uncaught SyntaxError: Unexpected token 'F', "Field 'des"... is not valid JSON at ce.parse [as parseJSON] (<anonymous>) at Object.success (script.js:164:22) at c (jquery.min.js?3.7.1:2:25304) at Object.fireWith [as resolveWith] (jquery.min.js?3.7.1:2:26053) at l (jquery.min.js?3.7.1:2:77782) at XMLHttpRequest.<anonymous> (jquery.min.js?3.7.1:2:80265)
    what should i do ?
Rashida Rahman
Rashida Rahman
Support Agent 1 year ago #191853
Sorry for your experience.
Would you please share more details, such as version and other system specifications of yours? I have just tried to upload images in SP Easy Image Gallery, but it is working fine at my end.
It will be better to have your admin access in the hidden content box.
T
TKIF2016IT
1 year ago #191873
hi this all my access information , you can plz login and see by your self
T
TKIF2016IT
1 year ago #192115
hi , do we have any update
Rashida Rahman
Rashida Rahman
Support Agent 1 year ago #192173
Sorry for the delayed response.
I'm checking your issue. I need more time to find out the reason behind it, as the SP Easy Image Gallery is working perfectly at my end. There is something wrong with your site; that's what I needed to check.
T
TKIF2016IT
1 year ago #192219
ok , thank you so much
T
TKIF2016IT
1 year ago #192484
Rashida Rahman
Rashida Rahman
Support Agent 1 year ago #192491
May I take an Akeeba backup of the site?
T
TKIF2016IT
1 year ago #192577
yes , sure , you can do what you need
Rashida Rahman
Rashida Rahman
Support Agent 1 year ago #192637
Thanks!
Can I have your database access? Were there images in your albums before? If I remove tables from the database, would it cause any loss of data for you?
Best Regards,
T
TKIF2016IT
1 year ago #192713
Sure No problem the albums image is just test image and i gave access for the data
Rashida Rahman
Rashida Rahman
Support Agent 1 year ago #192716
Thanks!
Link to the database, please?
T
TKIF2016IT
1 year ago #192718
ok
Rashida Rahman
Rashida Rahman
Support Agent 1 year ago #192722
Actually I meant to say, where I need to put the credentials of your cPanel user?
T
TKIF2016IT
1 year ago #192737
in
Rashida Rahman
Rashida Rahman
Support Agent 1 year ago #192850
Sorry but this is clearly not your cPanel address!
T
TKIF2016IT
1 year ago #193074
sorry , i made a mistake it
Rashida Rahman
Rashida Rahman
Support Agent 1 year ago #193410
Thanks!
Please check now and let me know.
