I am using the Resort template and there are plenty opf lesser known Social media options but no Instagram? How can i add that one to the list in the template please?
Social Icons - No Instagram?
Marked as the solutionTemplates based on Helix3 does not have Instagram or Custom Social field, sorry.
In that case you have to use SPPB module in that same position to have all needed icons and links.
6 more replies
Thank you for reaching out, and I apologize for any inconvenience caused by this oversight. Are you talking about Helix Template options social media?
yes these ones: https://prnt.sc/XV1W3GgqzNa_
Could you kindly grant me access to your Joomla administrator to check the issue?
Sure all attached thanks, i am doing another site with the same template so if this is fixable please let me know how so i can do it to that one too !!
Where should i go exactly?
Ok no problem thanks
If you know basics of HTML, you can also use Custom module and put icons & links. Just use Font Awesome Free 5.15 class names. Nothing scary or hard for most webmasters.
