SP Simple Portfolio Video Size Issue - Forum | JoomShaper
Awaiting an answer Extensions
Asked by conshelf 5 years ago Last activity 5 years ago
I'm working on creating a Video Gallery and I noticed there is no way to control how the video appears in the Lightbox after clicking "Watch"
I'd like to display the videos a bit larger and without the extar white space to the right, is there a way to do this?
Here's a link to my site.
Kind regards,
John
Ariba Staff
Yes, thank you for providing the link. I will check from my end and share the solution soon. Kindly give me some time.
conshelf Asked this
Hi Ariba,
I found the video size hard coded around line 67 in this file:
components/com_spsimpleportfolio/views/items/tmpl/default.php
I created a template override (templates/dentro/html/com_spsimpleportfolio/items/default.php) and changed width="500" height="281"to width="800" height="450"
I also found an issue with the z-index on the this CSS located here:
components/com_spsimpleportfolio/assets/css/featherlight.min.css
.featherlight {
    display: none;
    position: fixed;
    top: 0;
    right: 0;
    bottom: 0;
    left: 0;
    z-index: 2;
    text-align: center;
    white-space: nowrap;
    cursor: pointer;
    background: #333;
    background: rgba(0,0,0,0);
I changed the z-index to 9999, this way, the overlay covered the top header.
Would be nice if video size fields (for desktop, tablet and mobile) were added in the admin section of SP Simple Portfoilo like we have in the SP Page Builder addons.
Kind regards,
John
Ariba Staff
Glad to hear that you could solve the problem, and thank you for your kind suggestion. I will share it with my Developer team, for sure.
