Ends in 13d 01h 21m 16s
Language CONSTANT - Debug goes Blank
Asked by Preamble 9 months ago Last activity 9 months ago
We aorking with an extension DJ-classifieds and need to alter some Text of a Language Constant.
We are using TIXON template
WHen we enable Language Debug... The Home page loads to just a Blank page.. SO we are unable to see the Constant used...
We have searched for it on the backend and can not find it..
Please help...
https://thedocklocker.com
Preamble Asked this
We found it ourselves. DJ support said to turn on Language Debug.. which we did , and breaks the site, showing a blank home page after enabling Language Debug.
So if we use Joomshaper template. We cant use Language debug within Joomla...
PLG_DJCLASSIFIEDSPAYMENT_DJCFSTRIPE_PAYMENT_METHOD_DESC
4 more replies
9 months ago · edited
what phrase you are looking for?
If from template, as always, in template .ini file >> language\en-GB\en-GB.tpl_shaper_tixon.ini
If from DJ-classifieds, the same location, but with the component name on it. For example: language\en-GB\en-GB.com_djclassifieds.ini
But it's not our compoment, so I cannot help more.
There is also OLD Joomla trick.
Rename folder name "language\en-GB\" and then you see only BIG LETTERS - the lang phrases.
Preamble Asked this
This for Text of Payment Pluin within DJ-Classifieds...
Wanting to change Text of STRIPE description (See attched)
I've looked through all CONSTANT that start with DJCLASS* and can not find it
I'll look through that .ini file ....
I open this ticket because the Language Debug is not working in the template.. and would show me the exact CONSTANT in less than 2 minutes....
https://www.imgbly.com/D47dfeIMhGA2B14
I don't understand, just check language files or ask DJ support.
Info that something has a star doesn't help as much it could. I use other methods.
