Ends in 12d 19h 43m 54s
How to change the Background color og finion hero-section
Asked by Petra 5 years ago Last activity 5 years ago
I'm using the Finion template and want to change the color of the background of the hero-section.
https://prnt.sc/1vpv8xh
I want to change the gradient color!
Thanks!
Use this custom css
.hero-section:before{
    background-image: linear-gradient(to bottom, rgba(0, 0, 0, 0), rgb(105 220 204 / 75%)) !important;
Note: Path towards custom CSS: Extensions>Templates>Styles> Click on your current default template name then choose Template Options. Then find custom CSS within the custom code.
4 more replies
Give me that specific page link please. So that I can check and solve the issue
-Regards
Petra Asked this
see attached information.
Thanks!
Petra Asked this
thats worked!!
Thanks!!!
