Sp Booking Search Not Working For Package - Question | JoomShaper
A
arda
Extension 3 years ago
Hello, When I try to search a package from homepage sp booking search it leads me a page and give this error message:
"0 Call to a member function getParams() on null"
How can I solve this problem? https://prnt.sc/y7cWW2z0DVie
And also how can I translate checkout part? I open a topic about that 1 week ago and there is no answer? Please help me. I translate all part of this extension but only this part I couldnt. https://prnt.sc/ElOaknKWekYj
Toufiq
Toufiq
Senior Staff 3 years ago #102696
-Thanks
A
arda
3 years ago #102743
Ofcourse here you can check it.
Toufiq
Toufiq
Senior Staff 3 years ago #103215
Please check now. Thanks
A
arda
3 years ago #105505
Thank you, its working for homepage now but there are another problems
For the package page, If try to use search bar its not working for category. When I try to choose category and click search it leads me to homepage if I use seo friendly url. And my second problem how can I increase the max price for the package filter?
A
arda
3 years ago #106212
for package page search bar, if i select checkin and checkout date and search, it says no package found, even if I have available package between selected time.
Toufiq
Toufiq
Senior Staff 3 years ago #106556
Will you please provide me the FTP access to check the issue? I will check & get back to you soon. Thanks
Toufiq
Toufiq
Senior Staff 3 years ago #106567
A
arda
3 years ago #107185
Thank you so much for your help but there is still same problem with checkin and checkout date problem with search bar. I have available packege but still if I choose date from search bar for packge there is still "No Packages Found!" message.
Toufiq
Toufiq
Senior Staff 3 years ago #107294
Will you please share an screencast video?
V
Vladimir
3 years ago #107324
I also have a problem with the search. On any page, select any search parameters click Search- and automatically redirected to the main page. What should I do? http://new.tur46.ru/package
Toufiq
Toufiq
Senior Staff 3 years ago #107421
@Vladimir Will you please provide me the Joomla administrator access to check the issue?
V
Vladimir
3 years ago #107447
Good afternoon Certainly! I have more questions that I asked on the forum, but the answers are not very clear to me
Toufiq
Toufiq
Senior Staff 3 years ago #107496
@Vladimir solved package search. Need time to solved edit issue.
V
Vladimir
3 years ago #107645
Fine
Toufiq
Toufiq
Senior Staff 3 years ago #107811
Is it possible to provide me a screenshot or screencast video of your issues?
