SP LMS - Problem With Listing Lessons Under Course Topic - Question | JoomShaper
hv.digital
hv.digital
Extension 3 years ago
Dear Joomshaper, I have a problem with listing of lessons under all of my courses. I have created two topics under the same course and add only one lesson to each topic. But at the frontend the layout is competely off. Both topic have the same lesson under it even if they a created separately as you can see at the image here: https://ibb.co/Q9wNBGK I will send you all required login details at the Hidden Content area, please feel free to test it by your own.
Support Agent 3 years ago #103828
Thanks for the update. Please accept any answer to close the issue. There is a button to accept answer after each comment.
Support Agent 3 years ago #103221
Hello hv.digital
Apology for the inconvenience. I could not get your issue. Could you please share screenshots of the issue from the frontend? Then I will be able to understand and check the issue.
hv.digital
hv.digital
3 years ago #103414
Hi Khan, Please try to test iz by changing lesson name. Duration looks good but lesson name is duplicated for some unknown reason.
https://i.postimg.cc/66nLMxtS/issue-img.png
hv.digital
hv.digital
3 years ago #103825
Everything is working fine now. Thank you.
