After 1/2 hour on this setting, I give up.
How can we align vertically Icons group, with the same gap between all lines ?
https://tinyurl.com/2bqraxlj
Solved
SP Page Builder
Addon Icons group
Django Asked this
This custom css does not change anything. So I did the layout in another way, with JCE. See hidden content. Not the best, but it works.
4 more replies
Thanks for contactig us. Could you please give me your site URL so that I can check?
Django Asked this
The third Icons group addon at the bottom. (Page under construction).
Use this custom CSS
#sppb-addon-1681490153837 .sppb-icons-group-list li {
margin: 0px !important;
Ok now worries, its also work like this, Thanks for sharing the solution. You can now close this post by accepting the answer.
