BUG with active link color on mobile menu - Forum | JoomShaper
Solved Helix Framework
Asked by Laurent 3 years ago Last activity 3 years ago
I have found a bug on active link color on mobile menu.
When I click on link number 1, then all other links takes the same active color.
See here : https://www.screenpresso.com/=DFcYf
Could you please fix it?
L.
Rein
Hi Laurent & Mehtaz,
This is known problem already and should be fixed in the next update Paul answered in the thread were I mentioned this bug.
It is present since version 2.0.12
See this post: https://www.joomshaper.com/forum/question/25185
Regards,
Rein
Thanks for the information.
7 more replies
Thanks for contacting us. Could you please give me your site URL? So that I can check?
Laurent Asked this
see Hidden Content area.
Use this CSS in your custom.css file
.offcanvas-menu .offcanvas-inner ul.menu li.active a {
    color: #181715 !important;
.offcanvas-menu .offcanvas-inner ul.menu>li a:hover, .offcanvas-menu .offcanvas-inner ul.menu>li a:focus, .offcanvas-menu .offcanvas-inner ul.menu>li span:hover, .offcanvas-menu .offcanvas-inner ul.menu>li span:focus {
    color: #cf8000 !important;
Laurent Asked this
I have added this code.
works but now, when a link is clicked, the active color has gone.
Isn't it ok? You want this feature right?
Laurent Asked this
Yes this feature seems to be logic indeed.
It is ok right?
Laurent Asked this
no, does not work for the moment
Laurent Asked this
thanks
