Mobile issue with sidebar - can't position at bottom of page - Forum | JoomShaper
Asked by Dina Abramson 3 years ago Last activity 3 years ago
I saw that first column is last. Maybe too many people were logged and tried to make corrections, hahahha
like passangers on the back sit telling driver, turn left, no turn right, no ride ahead...
Create new page - set 3 columns, and play a while, and you will know how it works.
And yes, logout all extra users from admin.
I think we cannot help more.
4 more replies
Hi Dina,
it's very easy. In Column Settings > Responsive > Column Ordering > choose value for Tablet & Mobile
It's based on CSS order Property >> https://www.w3schools.com/cssref/css3_pr_order.php
By default, first column has value 1, second 2, thrid 3. But you can change that for Tablet and Mobile view, using 1-2-3 value for each of them. Just set "3" for first "left" column for Mobile view. This kind of logic.
Yes, I made that change for article "Our Services" (Id 94) - now it's your turn for others.
Dina Abramson Asked this
That's what I did, and I put it down as far as possible, but it doesn't recognize it or i have not done it right. I ordered all the columns in the order i needed. Some moved, some didn't. Not sure what I'm doing wrong.
Thanks for contacting us. You can follow these steps below:
Go to that column settings --> Responsive --> Column Ordering --> and then choose the value you want.
https://prnt.sc/sUoBpQvxRUsB
I figured out how to fix it. had to move the bottom row into the row I wanted first.
then it worked.
Glad to know that.
