Hi peeps
Is it possible to link to a specific accordian item from another page.
So I would like to add a link to page which when clicked opens the accoridan page with a specific accoridan item open.
Thanks for helping
Alison
Hi peeps
Thanks for helping
Alison
Thanks for contacting us, Could you please give me any example of your issue?
Hi Alison.
This is possible only with the help of complicated JS coding, but not using SPPB functionality.
Thanks Pavel for your answer - shame it would be great to be able to use a anchor for this (#)
Joomlart have this function, maybe it is something that could be looked at for the future.
Its not possible in same accordation, maybe it will be possible by multiple accordation. If you set it in same accordation then you have to set it in closed tab, then it will not open because in each accordation tab there is an unique ID. By the way I will also inform our team about it so that they will think about it and maybe if possible they will add it in future.
Thanks.
Thanks Mehtaz
You are most welcome. You can now close this post by accepting the answer.
