problem with a link SP Page Builder - Forum | JoomShaper
Asked by Ana Gud 2 years ago Last activity 2 years ago
When I add link to the text on the page or via button and if I add it using SP Page Builder where it offers me to choose the page, then the link opens the page but without top part of the page.
To see the problem, please:
Open this page - https://parustrans.ru/uslugi-kompanii-po-perevozke-lichnih-veschey/perevozka-lichnikh-veschey in the text on the right you will see the blue text with the link if you click on it you will get this page https://parustrans.ru/en/?option=com_sppagebuilder&view=page&id=86 instead of this page - https://parustrans.ru/uslugi-kompanii-po-perevozke-lichnih-veschey/khranenie-lichnih-veshey-pri-perevozke-lichnih-veshey
Why sp-page builder is not adding the link in its correct look and doesn't display the top part. Please fix it.
Ziaul Kabir Staff
Hello Ana,
Thank you for reaching out to us. Were you referring to this link?
Thanks for your cooperation.
Edit:
Please check your page in screenshot 2. This is your page ID: index.php?option=com_sppagebuilder&view=page&id=86.
If you want to link text to a page, please use the menu link instead of the page, page will redirect you to based on page id.
Thank you.
Ana Gud Asked this
ok, thank you and you don't think it's a bug? how anybody supposed to know it?
Ziaul Kabir Staff
Thank you for your reply.
To clarify, this isn’t a bug. When you add a link to a specific page, it will direct to that exact page. However, if you’d like to attach a link to a menu item, be sure to use the active menu item name, which will redirect to the corresponding URL.
If you have any further questions, please let me know. Otherwise, feel free to mark this question as complete.
