Ends in 12d 17h 58m 23s
J2commerce
Asked by ANT 1 year ago Last activity 1 year ago
Hello ,
Are some of your templates made to work with J2commerce ( ex J2store ) ?
If yes how can I find them ?
Thanks for contacting us. Yes, still we have some templates that are work with J2store. You can check our E-commerce templates. Specially Arino, E-sports, Shopin, Unie.
You can check templates details then you can find it. Like this link below:
https://www.joomshaper.com/joomla-templates/unei
https://prnt.sc/yeCN57KOB_9G
You can also check the templates documentations.
https://www.joomshaper.com/documentation/joomla-templates
https://www.joomshaper.com/documentation/joomla-templates/arino/e-commerce-by-j2store
https://www.joomshaper.com/documentation/joomla-templates/esports/e-commerce-by-j2store
Something like that. Hope it helps.
ANT Asked this
ok, thanks
FYI : when trying to install UNEI :
Table 'sc1weblor_mydb.khan3_easystore_media' doesn't exist
ANT Asked this
I tried Shopin Quick start, same issue
ANT Asked this
I finally found how to by empty the database before.
But in Shopin, for exemple, I did not find J2store sample data neither J2store installed.
I retry others QuickStart
Could you please create a new forum post about this new issue?
