Help, My Website Isn't Working - Question | JoomShaper
Y
yoquiltrucci
Helix Framework 1 year ago
it was working fine minutes ago suddenly my website only shows as a white screen with 2 hamburguer menus?
please see www.grillhouseparrilladas.com
Senior Staff 1 year ago #195097
HI,
Try this method:
  1. Remove all custom Javascript code, including Tag Manager, from Template Options
  2. Download and install Phoca site plugin (phoca.cz)
  3. Inside setting of Phoca Site plugin insert your custom code + publish plugin
Then all should be OK.
If you have RSFirewall - before step 3 - add your IP as trusted to White List inside settings.
Y
yoquiltrucci
1 year ago #195459
Hello, i followed your instructions i could insert the code via Phoca plugin
do you know when could we use the helix custom code again to insert google codes?
Y
yoquiltrucci
1 year ago #195084
I noticed it has something to do with Meny and Off canvas menu and with custom code Google Tag manager code
i am trying to insert google codes and there the template keeps on Drafting and shows error then i get the double hamburger menu and everything else got white-blank screen
then i go to Menu, select only menu, and then the website shows again but no google code
please see attached file
https://postimg.cc/rKhLHZxN
Support Agent 1 year ago #195094
Hello yoquiltrucci,
If you could kindly provide any additional information regarding the issue, it would greatly help me investigate and address it more efficiently. Please share your administrator access here to check the issue. Use the Hidden Content box to share the credentials. Make sure that you have a full site backup before sharing.
Y
yoquiltrucci
1 year ago #195457
Hello, any news?
Y
yoquiltrucci
1 year ago #195458
Hello, any news?
Senior Staff 1 year ago #195486
About Google tracking, in Template Options > Advanced > you have option to add Google Analitics ID, and it's all you have to do.
ABout Phoca Site, is so tiny plugin that you should use it, and relax.
