SP Pagebuilder display posts as blog - SP Pagebuilder Beiträge als Blog anzeigen - Forum | JoomShaper
Asked by Matthias Wulff 1 year ago Last activity 1 year ago
Hello everyone,
I want to create our club page in SPB. It's working great. Now several editors want to create posts. I'd like to create them in SPB as well. Unfortunately, I can't create them as a blog, for example, on the homepage.
Is there a solution? It's very cumbersome to first create a Joomla article and then style it in SPB...
Or is this feature in the planning stages? Thanks for any suggestions or information on this topic.
Hallo zusammen,
ich möchte unsere Vereinsseite in SPB erstellen. das klappt auch Super. Nun wollen mehrere Redakteure Beiträge erstellen. Die würde ich gerne auch in SPB anlegen. leider kann ich diese nicht als Blog z.B. auf der Startseite der Homepage anlegen.
Gibt es da eine Lösung? Ist sehr Umständlich, erst einen joomla Artikel anzulegen und anschließend im SPB zu stylen...
Oder ist die Funktion in Planung? Betsen Dank für einen Lösungsansatz oder eine Info zu dem Thema.
Is this helped?
3 more replies
Hello!
Did you mean you need Blog type layouts in Page Templates/layout packages of SP Page Builder pro?
Actually, category blog is not achievable with anything except Joomla Articles since it's native Joomla feature. The positive aspect is that you can create a article details view by utilizing the SP page Builder editor with the help of article integration of SPPB. The below bog might be beneficial: https://www.joomshaper.com/blog/beautify-your-joomla-blog-posts-with-sp-page-builder
But with SP Page Builder pages you can not create a category blog, because SP Page builder category is different from Joomla category. They are different.
But if you wish to, you can try to use the articles addon of SPPB to show your articles in a SP Page Builder page. With the settings of the articles addon, you can design how many articles you want to show with how many columns.
https://www.joomshaper.com/documentation/sp-page-builder/sp-page-builder-3/addons#articles
Hope this is helpful anyway!
Matthias Wulff Asked this
Sorry for the late reply. I was away on business, working on a construction site. Yes, I managed to get some of it done. If I were maintaining the site myself, it wouldn't be a problem. But there are several authors involved, and it's too much of a hassle for them. I'll probably outsource the blog and create it some other way.
Hallo,
sorry das ich mich jetzt erst melde. Ich war beruflich außer Haus und auf Montage. Ja, einen Teil habe ich hin bekommen. Wenn ich die Seite pflegen würde, wäre das nicht das Problem. Aber es sind mehrere Autoren beschäftigt und denen ist das zu umständlich. ich werde wohl den Blog auslagern und irgendwie anders erstellen.
No worries. And glad to know that its solved. And thanks for accepting the answer.
