Ends in 12d 19h 55m 18s
Pitech template - off menu issues
Asked by Mark 5 years ago Last activity 5 years ago
Is there a way to change the "burger icon" and background color on the menu bar in Pitech template. Also the main menu is repeated in the off-menu display...
Thanks!
Ariba Staff
Thank you.
However, I could not log in to your admin area.
Please add the following css rules in custom css section
.burger-icon > span {
    background-color: #000;
#sp-header {
    background: white;
.offcanvas-menu .offcanvas-inner .sp-module:nth-child(2) {
    display: none;
Hope this will help you, please do let me know if you have any confusion.
6 more replies
Ariba Staff
Thank you for your query.
Can you kindly share your admin access? Use the hidden mode to share the log in credentials.
Mark Asked this
Sure ... see below... thanks!
Ariba Staff
Thank you.
Could you kindly let me know which color you want to apply on the background?
Also, where do you want to make the changes specifically? When we scroll down, the white menu that appears on top - do you want to change that? Or the transparent one at the top ? If you could kindly share a screenshot highlighting that part, it would be great.
https://imgur.com/ - You can use this to share the screenshot here.
Mark Asked this
5 years ago · edited
Here is the screenshot... where the YELLOW is on the top right is where the off-menu icon is but since it is WHITE and the background is also WHITE you can't see it. Sooooo...
We can either change the off-menu icon to BLACK or change the background color of the header/menu to blue. It would be ideal if it is NOT transparent to start also.
Would you be able to advise me on how you made the changes so I can do it going forward and not have to bother you for this! Thanks!! :-)
<a href="/https://imgur.com/LizVV6v"><img src="/https://i.imgur.com/LizVV6v.jpg" title="source: imgur.com" /></a>
and here is the double-menu:
<a href="/https://imgur.com/mJARzeb"><img src="/https://i.imgur.com/mJARzeb.jpg" title="source: imgur.com" /></a>
Mark Asked this
Thank you!!
Ariba Staff
You are most welcome.
