How to change layout options - Forum | JoomShaper
Asked by Jorge Muralles 5 years ago Last activity 5 years ago
Hi Folks, I am sorry to bother you.
I have to questions.
  1. Question 1
If I have a row with colums in them, and add ons in the colums, is there a way can change the columm lay out with out loosing everything.
so if I have
4+4+4 in a row and then I wanted to add another column
4+4+4+12+12 for example
I do not want to loose what I have i nthe first row (4+4+4) I just to add more content below it.
Question 2
  1. When I add two rows to a lay out, I get a big gap between the rows, I have not been able to find where this can be controlled.
I tried to upload a pic for you to see the problem but I cannot using this form.
Here is a link to the article where you can see the issue:
http://www.conozcamosguatemala.com/lugares/39-esquipulas
I am talking about the text between the paragraphs below the image.
Thank you very much
Jorge Muralles
Rashida Rahman Staff
Thanks for your query.
Yes, you can. It will not lose the addons you already have. Please keep in the structure the old ones also.
I have checked your site and found out sections getting padding values there. Please check the style tab of the section and remove/modify the padding values there as per your need.
https://prnt.sc/1us4qj7
