Ends in 12d 17h 59m 26s
Modul position in fixter header: vertical (left)
Asked by Die Internetschmiedin 5 years ago Last activity 5 years ago
Hello, I need a module position in the header (vertical, left) so that I can insert content under the menu.
Hi. Try this code.
.logo, .sp-megamenu-wrapper {
    order: -1;
Will looks like this
3 more replies
Die Internetschmiedin Asked this
this answer doesn't help me.
The template fixter already has a vertical menu in the section "sp-header".
I need a way to display modules in this section under the menu in the desktop view.
http://relaunch.gs-flachslanden.de/
-Regards
Hi Pavel,
danke das funktioniert :)
