Hi There
The author link in articles do not work in Shaper Gazette after upgrade.
The Author component does not have a download in Gazette see the screen shot.
Hi There
Adriaan Buys,
Please go to this location: emplates/shaper_gazette/html/layouts/joomla/content/info_block and replace author.php file with the attached file. You need to unzip the file and then replace.
Hello Adriaan Buys
Please share the screenshot of your issue to understand it better. Take a screenshot and share via any platform. For example: Lightshot or Imgur.
This is not linked because it is not developed that way. You can customize the file at this location: plugins/system/helixultimate/overrides/layouts/joomla/content/info_block/author.php
Hi Ofi
That is totally incorrect information. I have had this website for more than two years. The Author component caused the author name to be a link to the authors profile and his articles. When you clicked on the authors name it took you to his profile.
I have done this hundreds of times during the two years.
Can I please get an answer on this - kindly look at your own demo https://demo.joomshaper.com/?template=gazette the author's name does link to their author profile. Select any article and you will see.
Apology for the delay. I have lost my grandfather last week and had a bike accident later on this week. I am still recovering.
Anyway, firstly, I have checked with the Quickstart and replied to you. Now I checked the demo. Actually, this feature was in the previous versions. On the latest version, it was removed. I have checked both Joomla 3 and 4 quickstarts. I have also talked with the developer team about this. They assured me that it will be added in the next version. Thanks for your patience and time.
Thank you, Ofi, condolences for your loss! Hope you are all recovered :)
Any news or timeline for this fix?
You are welcome. Thanks for your condolences. Yes, I have recovered. Unfortunately, this will be delayed. I have informed the team about it.
Thank you, please this is urgent. It may not seem like it but I have authors that write for me and they get upset - nobody can find their details from the article. If it is not fixed soon I will need to start putting postscripts for the writers.
if prolem still exsist this may help
https://www.joomshaper.com/forum/question/14907#qa-answer-72264
Hello, I have the same issue and the link provided with the fix does not work. Thanks.
jalaljoblo,
Thanks for sharing the solution here.
Thank you this worked!
You are welcome 😊
I have a humble request. It would be very kind of you if you can manage some moment to give us feedback onÂ
