Overrides. What are these?
Asked by Ronny Ko 4 years ago Last activity 4 years ago
hi,
I have a dumb question. I was wondering what these Overrides that I see when I am in the home Dashboard. I kepeing that the number of overrides has increased over time. Should I be concerned?
Hello Ronny Ko
This is a new feature which shows the differences come from any update. You can check what actually the changes are by clicking on Overrides to Check. It will not create any issue. It is just an extra option on your hand whether to check the changes.
Pavel shared a good YouTube video. You can have a look and you will get it.
