Hi, in case of a section on 3+9 layout, the part 3 fall on top of the part 9 on mobile view. How to do to have it to fall on the bottom of the part 9?
I fact a layout 9+3 should do the job, but there's no option....i'm i missing something here?
Awaiting an answer
SP Page Builder
3+9 layout section trouble on mobile view
5 years ago
· edited
You missed/forgot about built-in option.
Check Columns options - Responsive - Tablet Order and Mobile Order.
Just set "1" for part 9 (2nd column) and set "2" for part 3 (1st column).
Use back-end editor probably easier to find it.
Phil973 Asked this
Hi, Thanks Paul, it's great to receive a concise & precise answer.
Appreciate
