Hi, I am using Joomla4 with helixultimate and most pages made with pagebuilder - all ok
but when I look at the mobile vertical version the logo does not resize as it should and this brings the hamburger below the logo instead to the right of the logo.
see https://aziendacs.it
very grateful for any hint you can give.
thanks in advance
Rita
logo and menu on mobile not working as should do
Marked as the solutionHi Rita,
Really glad to know that your issue is solved now.
You may accept the most useful answer in order to close the post.
3 more replies
Thanks for reaching out to us.
Did you try to put the logo height and header height same for the mobile version? You can do this by selecting the device icon from the top bar of the template edit window. Here is sample screenshot for your convenience: https://prnt.sc/IoEAPNSfjuey
If yes, would you please give me your admin access?
Hi, I have seen your image - you have the choice of view in the top - which I do not have - maybe my version is not up to date?
Anyhow I give you the access credentials in the hidden content
thank you in advance
Rita
Hi Rashida,
just to say that I now got my issue sorted - thanks anyhow.
have a nice day
