Staff replied General
Some errors after J4 migration
Asked by Libor 3 years ago Last activity 2 years ago
Hi, after transfer of my page to live domain i have some errors in top and footer of tha page.
Top.
Deprecated: strpos(): Passing null to parameter #1 ($haystack) of type string is deprecated in /data/web/virtuals/169923/virtual/www/domains/la-palma.cz/plugins/system/ampz/ampz.php on line 1094
footer:
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /data/web/virtuals/169923/virtual/www/domains/la-palma.cz/templates/shaper_travelia/html/layouts/chromes/sp_xhtml.php on line 28
Other error in SP Property component :
Warning: file_exists(): open_basedir restriction in effect. File(/components/com_spproperty/assets/css/owl.theme.default.min.css) is not within the allowed path(s): (/data/web/virtuals/169923/virtual) in /data/web/virtuals/169923/virtual/www/domains/la-palma.cz/components/com_spproperty/views/property/view.html.php on line 87
Deprecated: trim(): Passing null to parameter #1 ($string) of type string is deprecated in /data/web/virtuals/169923/virtual/www/domains/la-palma.cz/components/com_spproperty/views/property/tmpl/default.php on line 109
Many thanks for help.
htttps://www.la-palma.cz
Hello Libor
Apology for the inconvenience. I have fixed your issue on the footer by modifying the code here:
For the header issue, I have disabled the plugin.
https://prnt.sc/TRdRamBBPbCJ
Please contact the plugin developer for support.
Libor Asked this
Hi Ofi,
many thanks.
I have other errors:
SP Property
Deprecated: trim(): Passing null to parameter #1 ($string) of type string is deprecated in /data/web/virtuals/169923/virtual/www/domains/la-palma.cz/components/com_spproperty/layouts/properties/property.php on line 129
https://www.la-palma.cz/nabidka-realit/nabidka-realit
and
https://www.la-palma.cz/nabidka-realit/nabidka-realit/154-dum-puntagorda-3481
SP Booking
Deprecated: json_decode(): Passing null to parameter #1 ($json) of type string is deprecated in /data/web/virtuals/169923/virtual/www/domains/la-palma.cz/components/com_spbooking/helpers/helper.php on line 660
https://www.la-palma.cz/nabidka-ubytovani/autopujcovna/2-ford-ka
Many thanks for help. Libor
Apology for the delayed response. Please update SP Property and check the errors.
