Ends in 12d 08h 35m 59s
navigation element
Asked by Jim 1 year ago Last activity 1 year ago
Hey,
i use this element for some long-content pages. BUT: one link will be extern, a link to another domain.
When i activate "Scroll to" the extern link doesnt work.
Is the "Scroll to" just a smooth scroll option? or what its for?
a #idname works but good to know what it does...
Hello Jim,
Thank you for reaching out to our technical support forum. I’m sorry to hear about the trouble you’re experiencing.
Sorry, the external link does not work when you turn on Scroll To option. Because on data-scroll-to attribute is added to the anchor tag. I will talk to the developer team to fix this.
When you turn on Scroll To and set Scroll Offset, this tells the scroller how much it should scroll when clicked. For example, if you set scroll offset 100, there will be 100px space on top of every section. Suppose, you have 5 sections with internal links. Now, if you go to third section by clicking the menu item, it will take you to the third section but will keep 100px on the top. If you set 200 Scroll Offset, then it will keep 200px space on the top of each section when clicked.
I hope that I could make you undestand how it works. Let me know if you require further assistance.
Jim Asked this
so its the offset and the attribute which are added. ok.
just a # ID-NAME works for me. so all good.
Thanks. If the answer resolved your query, you can mark it as accepted to help close the post and guide others with similar questions. There is a button to accept answers after each comment.
If there's anything else you need assistance with, feel free to let us know!
I have a humble request too. It would be very kind of you if you can manage some moment to give us feedback on
  1. Joomla Extension Directory
  2. TrustPilot
Just checking in to see if you have feedback on the provided solution. If the answer resolved your query, you can mark it as accepted to close the post and guide others with similar questions. You’ll find a button to accept answers below each comment.
If you need further assistance, feel free to let us know!
