Hello!
How to remove it?
<a href="/https://ibb.co/tXJ4W6t"><img src="/https://i.ibb.co/bJKP8VZ/1.jpg" alt="1" border="0"></a>
How to remove it?
Thank you for your query. Do you want to remove that entire section?
Please provide your site URL here.
Now the page created in SP PB is rendered in the standard Joomla template. How do I prevent the standard Joomla template from being applied to this page?
Thank you for the URL.
As the standard template is being used here, it is rendered this way. Please use a template of your choice from here: https://www.joomshaper.com/joomla-templates
Can I fix the problem without installing additional templates?
Sorry, you have to use some template in order to render your pages.
To use a different template go to Menu Extensions -> Templates -> Styles. And choose a different template as default. If there is no template availabe then you need to install a new one.
Please read the following tutorial to know more about Joomla templates.
https://docs.joomla.org/Special:MyLanguage/J3.0:Getting_Started_with_Templates
If a special template is needed for SP PB to work, then I would like to see this requirement in the documentation. Now everything looks like you have installed SP PB and it works on Joomla.
Now the documentation does not say that it is necessary to install an additional template. Or I did not see this requirement.
Actually, you can do that using CSS but that won't be a good option.
SP Page builder works inside the component area only, but the header and footer section are under the template. So you will not be able to use SP page builder to control anything that goes beyond the component area.
If you do not like anything beyond this component area, then for those you can create a module and use it as per your convenience. And to remove those, you can then go to Module section, you will find the menu and log in module there. Also, in default template of Joomla, there are some active predefined module position too.
However, i would suggest you to use our templates as the menu structure of it is better and will be helpful for you. You can also use the Page builder layout packages to build your page.
Hope i could explain it clearly, please do let me know if you have any confusion.
I can see that you have downloaded Helix Ultimate now and everything looks alright from my end. If further you need any help, please do let me know.
You explained clearly. I tell you that this information should be reflected in the documentation for SP PB. It's not difficult to do this.
I understand, thank you for pointing that out, will keep that in mind & share with our team.
Please do let me know if you have any other query, i am happy to help :)
If you have no other problem, kindly accept the most useful answer in order to resolve the post.
Thank you
