Working with Template Travis on Helix Framework 2. There's only one preset available in this Template/Framework. How can I add some more presets? Please Help.
Regards,
Bert.
Regards,
Bert.
Yes Travus template has 1 preset option. If you want to add more then you can follow this documentation below:
-Regards
Thanks for your reply,
However, in the Travus template the xml files doesn't contain the option you mensioned befor in the documentation link. This was from older versions..... in those i knew how to edit the presets, in Travus it's a blur.
Only the option.xml contains the following script;
<!--Presets-->
<fieldset name="presets" label="HELIX_ULTIMATE_PRESETS" addfieldpath="/plugins/system/helixultimate/fields" icon="fa fa-paint-brush">
<field name="preset" type="helixpresets" default="preset1">
<preset name="preset1" label="Preset 1" default="#0345BF">
<color name="text_color" value="#000000" />
<color name="bg_color" value="#FFFFFF" />
<color name="link_color" value="#56BD97" />
<color name="link_hover_color" value="#044CD0" />
<color name="header_bg_color" value="#FFFFFF" />
<color name="topbar_bg_color" value="#333333" />
<color name="topbar_text_color" value="#AAAAAA" />
<color name="logo_text_color" value="#56BD97" />
<color name="menu_text_color" value="#000000" />
<color name="menu_text_hover_color" value="#56BD97" />
<color name="menu_text_active_color" value="#56BD97" />
<color name="menu_dropdown_bg_color" value="#FFFFFF" />
<color name="menu_dropdown_text_color" value="#000000" />
<color name="menu_dropdown_text_hover_color" value="#56BD97" />
<color name="menu_dropdown_text_active_color" value="#56BD97" />
<color name="footer_bg_color" value="#000000" />
<color name="footer_text_color" value="#939393" />
<color name="footer_link_color" value="#939393" />
<color name="footer_link_hover_color" value="#FFFFFF" />
</preset>
</field>
Regards,
Bert. Then you can use custom css in this case
I've tried but failed, nothing i do has an affect on the presetlist
Give me that postion screenshot which color you want to change. I can try it via custom css
![http://www.rustiekkamperen.com/images/Screenshot_Helix_Travus.png]
I want to have multiple presets here if possible.
Thanks,
Bert.
I cant access, Please check
Sorry for the late response, was very ill, now better.
Screenshot now available on:
![http://www.rustiekkamperen.com/Screenshot_Helix_Travus.png]
Glad to know that you are fine now.
I mean on your site which you want to change so that I can check and change the color of that portion.
I don't think you know what i want to change.
I'm building a website wich will contain like 10 similar templates, each template contains another color.
So, 10 copies of the Travus template, each with his own color. Is this possible?
Before this i tried to copy the template, renamed it and changed the colors. Joomla is not well responding on these settings and displayed the templates randomly. Of course were the templates chosen according to te category in the menu option.
I've done this before with another Joomshaper template Shaper-Educon, but in J4 it doesn't work this way.
I think this blog may help you
This is the same answer you provided two weeks ago(see above)...... doesn't work in Travus
If I may....
In that case probably you have to use separate custom CSS for each template "copy" or "view".
For example you can use HDCustomCSS module (https://www.hyde-design.co.uk/free-joomla-extensions/custom-css)
Then assign to "debug" position, create 9 copies of this module, with different CSS colors inside and assign to selected subpages (menu items). It always worked for me. Management is as easy as presets, the only difference is that you have to define the appropriate colors yourself using CSS. But you don't have to touch template core files.
