Helix 3 website inaccessible:
Error message - "Attempt to modify property "shortcode_tags" on null
Also similar message on trying to access admin page.
Hi Roger,
check topic: https://forum.joomla.org/viewtopic.php?t=987386
and https://forum.joomla.org/viewtopic.php?t=988125
You forgot to tell you what have to done before issue.
Maybe PHP version is set too high for installed plugins. PHP 8 may cause problems, set to PHP 7.3/7.4 for testing period.
In near future you should consider template migration/switch from old Helix3 into Helix Ultimate.
Yes, this same custom.css (if you used) can be used again.
Helix Ultimate is more PHP 8 friendly.
Thank you so much Paul. Swapped back to PHP 7.4 and site now working. MY other site is Helix Ultimate and happy on PHP 8.1. Is there a way to set PHP versions individually for multiple sites on same host. As the GUI on my CPanel seems to swap it for all websites..?
