Template Finion does not support a higher version of php than 7.4. Additional modules such as baGallery or baForm are not functional because they are not supported by the PHP version. What should I do in that case? Please help me
https://www.joga-alena.sk
PHP 7.4 does not support other Joomla modules
Hi Jan,
As I know Finion is based on Helix Ultimate so it should work on PHP 8.0.x.
What error message you have after switch to that PHP version, are they releated to template code ?
Hi. if I switch it to a higher version, the website shuts down completely.
You see WHITE/BLANK page?
Please in Global Configuration > Server >
and in "System" tab - set : Debug System: YES
and check this same page again.
I switched to version 8.0 and after a while the website worked for me. But now (after about 15 minutes) everything works correctly. Thank you for supporting
That's a good news.
If everything is working fine, you can disable Debug and Error reporting.
If I may ask one more question, could you advise me where I can change the image in the login window of the same Template? It's probably Ajax, but I can't find where exactly that file is located so I can change the background image. There's a guy on the phone right now. thank you very much for your help
/templates/finatic/images/login-sidebar-img.jpg
thank you very much
And another mistake , after unlocking the website, an error message popped up count(): Argument #1 ($value) must be of type Countable|array, null given
-Can you help me with that? Please
Fixed.
