Screen distorted on smaller screens - Forum | JoomShaper
Asked by Gavin Hogan 5 years ago Last activity 5 years ago
Hello Gavin Hogan
I have changed in the layout. Please check your site now.
Gavin Hogan Asked this
Hi, please revert the changes .. now logo is too large
https://ibb.co/zPjpXc8
Text showing behind the header is meant to be centred on the page not behind the header.
I changed it back. Please try this CSS to Template Options -> Custom Code -> Custom CSS
.menu-fixed #sp-reservation .sp-module:first-child{
    margin-top: -10px !important;
.menu-fixed #sp-reservation .custom img{
    max-width: 50% !important;
Thank you, i have tried your recommendation and I have implemented it although not in terms of my issue.
If you notice in Image 1, the white text "Welcome to Halls Haven Holiday Units" is centred i the page and looks correct, image 2 shows the same text in an incorrect position behind the header, this is what i am trying to fix. I am trying to ensure the text is centred on the page no matter the size of screen.
If i move the webpage from a large screen to smaller screen, it does not scale correctly.
Image 1 - https://ibb.co/YfqTpJX
Image 2 - https://ibb.co/ydhwwfF
Appreciate your help, thank you
I have fixed the x-axis position in the homepage text block. Please adjust y-axis position.
