HelixUltimate Website - Question | JoomShaper
Trans4mational Therapy Centre
Template 5 years ago
Hi I successfully installed the Helix Ultimate website and initially all wsa alright. I then went to the main menu manager and unpublised all the menu items, except about and blog. My reason for doing this is because i want the site as a stand alone blog site. However, after I unpublised the menu items, the About and Blog links returned a 404. I then republishd all menu items, thinking that would solve the issue but it hasn't. Now, every page, excpet home, returns a 404, any Ideas please?
The site URL is http://trans4mationaltherapy.blog/quickstart/
Joomla 3.9.26 Tmeplate: helixultimate_quickstart_j3_v1.1.2 (1)
Toufiq
Toufiq
Senior Staff 5 years ago #15255
-Thanks
5 years ago #15299
Hi thanks for the prompt response and apoligies for the delay in resonding.
Just to update you on what I have tried. I have created a new main menu item 'Test' and used Main menu item> Articles - category blog
Choose a category - blog That also produced a 404.
I then changed it Main menu item> Articles - single article Select Article - (article) Making of a Legacy That also produced a 404.
I also unpublished all the items in the Company menu (which replicates the Main menu) I've never seen this layer of before???
I hope the above info is helpful?
Regards Thom Domain ID PW below
5 years ago #15405
Since my last response, I have deleted and reinstalled the template file on my Joomla backend ans while the template has reinstalled as the original, there are two noticalbel differences. 1. the module near the bottom titeld: "Easy to use and customize" Has the grey background I set and all the main menu links return a 404. This kind of makes me think this problem is at the local host end, is that a possibility?
Regards Thom
Toufiq
Toufiq
Senior Staff 5 years ago #15463
Please provide me the correct login info.
https://prnt.sc/1236ys9
-Thanks
5 years ago #15567
Hi Toufiq
Apoligies, it seems some digits were added to the database i.e. bak.soft. xxxxx instead of just soft.xxxxx. Now even I cannot access the site. So, I have decided to delete the complete installation and start again.
So, you can close this enquiry and apologies for the inconvenience.
Regards Thom
Toufiq
Toufiq
Senior Staff 5 years ago #15621
Please close the forum post. Thanks
