How To Speed Up The Loading Speed Of The Mobile Version Of The Site? - Question | JoomShaper
Denis Mone
Denis Mone
General 5 years ago
I checked the website loading speed on the PageSpeed Insights service https://developers.google.com/speed/pagespeed/insights. In the full version, the speed is over 90%. On mobile - about 60%. How to speed up the mobile version?
Thank you
5 years ago #17342
Hi. I think this is an excellent result. More you are unlikely to be achieved without the use of third-party extensions that makes code easier for mobile .
Exemple - jAmp, Responsivizer, Яндекс Турбостраницы.
https://www.joomshaper.com/blog/ultimate-guide-to-high-google-pagespeed-score-for-websites-on-joomla
1
Senior Staff 5 years ago #17351
Hi. Also few improvements (speed up rules) inside .htaccess should help a little bit.
Check also if your server supports LiteSpeed Cache - if yes, install free plugin for it.
Also consider using Advanced Module Manager (RegularLabs) to reduce number of modules loaded and displayed on mobile version only, make mobile version lighter than desktop one. For example, on smartphone people don't scroll down at the bottom so often as they does on desktop etc. OR create mobile versions of some modules, with smaller images inside (but AMM is needed anyway).
Senior Staff 5 years ago #17352
BTW On some servers I noticed that mod_security slown down websites, it may be caused by too high level of protection. You can disable and run test again. Just for testing purposes.
Denis Mone
Denis Mone
5 years ago #18235
Thank you
