Ends in 12d 07h 23m 40s
INstalling a premium template to SPPB
Asked by Nick Cumber 1 year ago Last activity 1 year ago
I get an error message in SPPB 5.6.1 when attempting to import a premium layout, Travus 2.0.1
"Somthing Went wrong!"
This is a Joomla 5.3.1 site running on PHP 8.2.28
What am I mising?
Chris
You can't import templates into PageBuilder - is that what you are trying to do?
Nick Cumber Asked this
Hi Chris thaks for the response - atttempting to get my head around PB!
Basicallly yes - I have a joomla site up and running, installed PB pro and can access the "normal" layouts. I have "Travus" which I understand is a "premium " layout and was attempting to "import" it. (?)
This would be the first time I have needed to add a layout not avaialble under the basic layouts provided.
If not an "import" then how?
If you need Travus demo site, you have to download & install Quickstart Joomla 4 - like Joomla step by step.
As you can read in template documenation.
Hi Paul,
No I do not want to install Quickstart and all that comes with it. I am also already on Joomla 5 which your site says is compatible with TRAVUS template.
How do I add it to me PB interface?
  1. Create a subdomain, for example, test.my-new-site.eu
  2. Install there Travous Quickstart
  3. Update SPPB component
  4. Then export Page by page to .json files , there are just a few pages that you may need.
  5. On your current J5 site, create a new pages and import page by page using exported .json file.
  6. Remember that in QS there are dummy images, not real photos.
In big short, export what you need and you can. And on both sites you need SPPB 5.x installed.
