Section library and Page templates not working - Forum | JoomShaper
Asked by John Juhl 5 years ago Last activity 3 years ago
Hi guys,
having an issue when trying to access Sections library and Page Templates from within a SPPB page.
It doesn't work. It did the day before yesterday.
I'm using:
Joomla 4
SP Pagebuilder 3.8.0 PRO
Helix Ultimate
all latest versions
Joomla cache + Chrome cache has been cleared
Thanks, John
Hello John Juhl
John Juhl Asked this
Will do
This issue is solved. Please check your site now.
Super !!! Thanks.
You are welcome. Thanks again for your quick feedback about the issue.
Anthony Grinblat
@John Juhl, I have had the exact same problem since switching to Joomla 4. They keep telling me to "turn off mod_security" but there is none with GoDaddy.
I discovered when I DON'T put in my licence key, the Sections load but can't be used. When I put the key back in, I just get the spinning wheel of death.
Have you found a solution?
@Anthony Grinblat, to be honest, I wouldn't know - I started to build my own "library" - and thus haven't used the sections since back then.
The problem I had was on a now discarded web-site, so I don't know if it was site related or what - but I do recall that the Support solved the problem on MY specific site.
J:)
