I Can't See "top 3 Position" On My Template - Question | JoomShaper
A
Alejandro
Helix Framework 4 years ago
Dear team,
I can´t see the "top3 position" on my template: https://prnt.sc/1qvtm4p https://prnt.sc/1qvtsye https://prnt.sc/1qvugll
I don´t know how I can include the new position, I've created a new "layout" with top 1 / top 2 and top 3, but I get a new row under the logo and the menu.
Thanks, an advance
Rashida Rahman
Rashida Rahman
Support Agent 4 years ago #31912
Actually I had given you the module position related doc. Yes, custom header creation is different in this new version.
Glad that you have found it!
Rashida Rahman
Rashida Rahman
Support Agent 4 years ago #31331
Hello there!
Thanks for your query.
The following blog maybe helpful for you:
https://www.joomshaper.com/blog/a-detailed-guide-to-the-helix3-layout-manager
The module position creation process is the same as described here for Helix Ultimate too.
The pach of the templateDetails.xml file is:
\templates\shaper_helixultimate
And you will also be able to know which positions already exists there.
A
Alejandro
4 years ago #31631
Dear Rashida, I understand how work the layout system, my problem is that in layout area I don´t have the "top Bar" neither the "header" https://prnt.sc/1qyizy8 When I create those rows (top bar and header) https://prnt.sc/1qyjbax I see the elements duplicated, and I can't eliminated the "top bar" that show the template neither the "header" https://prnt.sc/1qyjk6c
And as you can see in my before post the modules are correctly assigned. I created a user for you, would you be so kind to login in to see what happens?
A
Alejandro
4 years ago #31804
Sorry, the new version in very different, I found this: https://www.joomshaper.com/documentation/helix-framework/helix-ultimate-2/custom-header
