<div>Hi, </div>
<p>I've stumbled on an issue with Sliders Page Break on the Helix Ultimate Template.
Clicking on the page break button will show the hidden article part, but clicking the button again to hide it no longer works.</p>
<p>This works with the same article & settings using the Casseopeia template, so it appears to be an issue/conflict with the Helix Ultimate template. </p>
<p>Is this problem known and is there a workaround? I'm using the Helix Utlimate Template 2.0.6 on Joomla 4.0.4.</p>
<div>Best regards, </div>
<div>Ian</div>
Page Breaks (Sliders) not properly working on Helix Ultimate
Thanks for contacting us. Sorry for the inconvenience. Can you share a screencast video of the full scenario?
-Thanks
I've not been able to reproduce the error on the site you provided.
https://toufiq.net/js/helix/pagebreaks
However, your site runs on Joomla 3, whereas my site runs on Joomla 4.
I have installed Joomla 4 and check here. Thanks
I've recreated the issue on the page you've provided.
As on my homepage, the page break sliders can be opened but no longer closed.
Thanks for the update. We will try to fix it next update. Thanks
You're welcome. Is there an estimate when the next update would be due?
We try to create the same issue on localhost. But, same issue not found locally. Still now trying to find out the issue. Thanks
